Temple of Ioun
I picked up SS4 for CC3+ with the handy discount code this month and put together my first dungeon with the Schley style, which I kind of like:
One weird thing I experienced though is that when I try to put down any sort of seating (pews, benches, etc. - anything from the "Table" symbols icon) in the main area it disappears. No other symbols seem to have this problem so I'm wondering if this is a CC3+ issue. I've attached the FCW file in case anyone's interested in trying to debug...
-Jedius
-Jedius
I like the map a lot!
The outer circle was one bitmap, while the hole was the same as the rest of the floor. I added a glow to the outer one, plus a very small transparency and edge fade.
The text also has a glow plus an inverted bevel to try to indicate it's carved in, not sure how much that comes through. Also a bit of a blur to soften some of the edges.
The hole has an inner glow to make it seem as if the "other side" of the outer circle is glowing too. There's also an small edge fade there.
Nice map. I really like the arc walls. The effects are also very nice. Well done.
Doh! Mappy, you're totally right, I forgot about that. Unfortunately for me I've already printed the map
Dkarr, thanks for pointing out the scale point...now I see what you mean. I think you're right about the pews. I guess I'm so used to just dropping down a 5' grid it didn't occur to me I could do something different, or shrink the grid size...
