John Speed City Problems
I'm currently working on a John Speed City and I'm having some problems. The roads will not go under the walls even if I send them to back or the walls to the front. Does anyone have any suggestions on why this is happening?
Pat
Think of sheets as transparent overlays for an overhead projector. The COMMON sheet is right at the projector light and will be drawn first. The sheets are drawn in the order in which they are listed. The ones closer to the top of the sheets list are nearer to the projector light (bottom)and will be below those closer to the end of the list (farther from the projector light).
It's a little confusing until you get used to it.
Pat
