Hexes
                    I use a game system that measures things in hexes, which is convenient.
Now I was wondering if I could use CC2 to create maps with a specific number of hexes in them. In other words, would it be possible to make an outline of something, then have CC2 scale the hexes to a general number fit in the outline? I kinda doubt it but wanted to ask anyway.
If you made the spacing 100 instead of the default 10, there are fewer hexes.
You can select a start location onthe map, then the opposite corner.
I know it was a lot to ask for.....
Hmm... You could locate or create hexes of the scale you need. Then place therm on the irregular map.
Then create a poly using that fill style - it can be any shape you want.
If the PNG has a transparent background, you'll be able to put this in front of your map.
