How to erase something on Hex mode (or in General - Layers?)
Hello
I'm really sorry but i do have A LOT of difficulties erasing something. I got the technique (click Erase, Select, Do it) but i think i have trouble understanding 'where' is what i seek to erase.
Here, i want to erase the lake i've drawn. The only thing i've managed to do was erasing all the Grid or erasing so the background could be seen.
I think i'm missing something when i want to select things to be erased.
Is it related to the Layer ? The sheet ?
I know this question has popped up a lot but every single time i want to tdo the Erase - Select - Right Click - Do It, i never seem to do it properly.
Thanks
(and sorry for my lousy English as i'm non native speaker)
Thanks
Try to perform a Info->List command on the lake to check the Layer AND if you can select it that way (the LIST command always works on entities whether they are select-able for Erase or not).
If it works and you get the Layer name, click on the layer indicator (white box top right starting by L:) check if the rightmost box next to the layer's name doesn't show an "F" meaning the layer is frozen. If so, click on this F to thaw the layer.
Now, another : I have created a map based on Par Lindstrom design in Annual 6. The maps is done and complete.
Then, i want to save this map in another file but using Hexagons. Hence, i just have to 'overlap' with hexagon (more or less).
However i'm stuck with the border.
I dont know how i did manage this but in green i've been able to overlaps the border (green), then i've done something... and now i cant anymore (red).
And i've been trying to do it again, i just cant.
Can someone enlighten me?
Many Thanks
So i'm out of clue
I dont want to appear negative here, but the learning curve is extremely complex. I really do think it is a great tool, but the interface is definitely something to improve.
Waiting for the help of someone. thank you.
