scaling two bmp imports ?
I am working on Traveller deck plans. I have finished the lower deck of the GazelleClose Escort. I was working on the upper deck, and it didn't look right.
I checked the borders on both maps. 23 x 48 meters. 1.5 meters per square. Both match.
I clipped/cut the scans of the deckplans, so the outermost walls of the engines matched locations.
But when I imported the bmp of the lower deck into the map for the upper deck... the corridors are way off. The upper deck walls extend outside the walls of the lower deck bmp. The central corridor of the upper deck is displaced slightly sideways to the right in comparison of the lower deck corridor.
How can I correct this ?
Thanks.
Thanks.
I'll have to make the lower deck slightly larger so the decks match.
