Create my own lgt files ?
🖼️ 280 images Departed Legend - Rest in Peace
I'm currently usng FT3 and export to Cosmo template to create worlds and moons.
The worlds exports are going well.
I would like to create my own lgt files so I can create gray moons with some small parts in color. To show minerals or ice.
So, what part of the file can I edit to do that ? I'll rename it so I can still make all gray moons and planets.
Thanks !
Thanks !
I really don't recommend directly editing the .lgt file directly as features that appear to be described in the file may not map to functional features in FT. Also, any given update may break changes made in the unused portions of the .lgt file.
I would recommend using FT's Lighting and Color options instead. The Altitude and Intensity options are the only portions of the .lgt file that are likely to be supported in the long run and those elements can be controlled from the UI there.
The Image Climate shader might be able to get something similar to what you're describing, I think. A noisy gray field with little specks of color might give you interesting results.
I've attached a false-color image of what I'm looking for.
Thanks !
