CC3 Mercator Issue
                    Hi,
I've had a long line appear on my map, diagonally throught the continent that I've just drawn. It appeared as i got the the point where the land default tool in the Mercator historical annual was about to rejoin the start point. I right clicked to finish the join, the coastline joined, and this line appeared cutting horizontaly through the join from top to bottom of the map.
The continent took quite a while to draw out, and i really don't want to have to do it again. Any ideas of how i can get rid of this line?
So to do it.. zoom in on the area..
Click on the Delete Node Command (looks like a box with a > and a minus between the box and the > ) then carefully click around the area, or on exactly where it messes up.
it -should- fix the problem.
Hope that helps
-Rob
-Rob.
