Jpeg / bitmap background
                    im not a very good map maker.  I dont have the knowledge to use the programs well and i dont have the patience to learn.  So, what i did was use the infinity engine from Baldurs Gate to export their already created maps.   Now i am trying to open them using CC3 so that i can alter the existing maps and add in things for my players such as a hex grid.  But CC3 wont recognize or open the files.    How do i do this?   Your help is appreciated thank you.
Then, you can do Draw > Insert File to insert the PNG file into your CC3 map.
Then when you insert the JPEG or BMP the map will stay the original size.
Works for me.
0,0 for lower left and then hold down the control key and move the mouse to the upper right, and click left mouse button when you reach the upper right.
Sometimes I have to start at the upper right and go to the lower left second.
For some reason it seems to like the bottom right corner first, then top left.
Peter
Also I turn grid and snap on, helps to position at the top left.
So far I didn't need to type coordinates.
