Weird Re-Scale Behavior
Finally got back to my map, when I've realized that something odd has happened. For some reason, my map has re-scaled itself and I can find no way to fix it. My map was orignially set up for 2000X2000 miles, but for some reason it is now 10000X10000. Does anyone know of any way I can rescale this correctly? I have no idea why it changed on me, I haven't worked on my map in a while. I went back and checked an earlier backup, and it correctly has an area of 2000X2000. It's been a while since I've worked on the map, and I'd hate to have to start from scratch again because the dang thing re-scaled on me without my knowing it (several of my backups are re-scaled). Anyone know how I can fix it?
    Simplest way would be to use the non-visual scale to scale it back again:
    1. Show all sheets and layers, make sure no layers are frozen
    2. Type SCALE on the command line, then hit A to select all entities, D for do it, 0.2 for scale, and 0,0 for origin.
    Another option is to enter the Drawing Properties dialog, hit the Drawing units button, and manually multiply the number in the "Inches per drawing unit box" by 5. Make sure the rescale option is checked. This should have the same effect.
  • edited October 2012
    Ah, that might explain it. I remember when trying to scale my symbols I input the scale in the wrong place. I might have done that, though I don't recall increasing any scale to 5. Oh well, at least there is a way to fix this. And I think you meant to say "divide by 5". :) Thanks Monsen!
