Not able to Select a Catalog
I started a new map and everything was working great, got it done and started a second map. When I selected structures the 'catalog file' came up (which it always does--kind of annoying but...). This time, the catalog I wanted 'CC3' filled does not display any icons and if I select the blank, my catalog menu remains unchanged.
I have gone into the advanced area and I cannot get it to come up this way either (allot of the menus are empty as well here). I own allot of the profantasy fantasy software (13 different packages for mapping) and don't know if any of these are causing the issue.
Any ideas on how to get the catalog files to show up again. I can add more detail if needed on what/how I am doing things.
Using the 'Open Symbol Catalog' allows me to open it up and use the symbols, however if I click on the 'Structures' catalog again, I do not have access to the 'CC3 Filled' again. I can manually open when I need it and this will allow me to work around the issue.
Is this a known issue or is there something I can do to allow me to access through the catalog file (I am not above doing a complete re-install if that is what it takes--if that would fix it)?
Thank you.
