Standard and Merge Layers
                    I've used for CC for small projects, but never really got into it.  I'm know set on really getting to understand it and have been impressed with all the stuff it can do when you try to wrap your head around it.
Anyhow, I think I understand Sheets and Layers, but I'm a bit confused about the Standard and Merge layer. I'm not sure what to do with them. The Template and Symbol Definition layers are also a mystery to me. I'd appreciate insight on how to use them. Any tips?
I believe the Template layer are there to enable the default sheets to exists. It has 16 single point entities on it, each on a separate sheet. By default, sheets without any entities on them are not saved with a drawing, so this is necessary to keep the sheets.
Not sure about the other two. I don't think they have any useful function you can utilize to do something special though. I usually just leave them alone.
Thanks.
I believe the Merge layer is used by CC3 to handle the effects in a map. I'm not sure of the exact workings of it, but if you hide the Merge layer, your effects won't work, so I think it's best to leave it visible and without any entities on it.
Hope this helps,
Erik N
Steve
In most cases when I use hide all, I do want to hide the symbols layer, because I rarely feel the need to see just symbols, nothing else. This just shows that people have have different needs, so it is better that a feature does what it says, rather than try to guess what layers the user might not usually want to hide.
In any case, the basic principle of the function is to enable you to hide all layers, because it is easier to just turn back on a few, than checking the hide box in 20+ layers.
