in FT3, rotate a map ?
🖼️ 280 images Departed Legend - Rest in Peace
I found a map in ft3 i want to use, but I would like to rotate it 180 degrees, swap east for west.
I don't see anything in the ft3 help file on this in rotate nor in export. No rotate method I can find.
The only way I can think of to do it in CC3, would be to import the map as a bmp or png, that has been rotated, and trace the map from that.
Is there another way to rotate a ft3 map ?
Thanks.
Thanks.
Note that the map is only rotated when you view it using this projection, but since FT3 export maps using the currently active projection, this shouldn't be a problem.
Obviously, since this is a rotation, it doesn't only swap east and west, but north and south will be swapped as well. If you want to mirror it instead of rotating it, I have no idea on how to accomplish that.
Projection 93, "Equirectangular Rotated 180" Scale 1.0 Description "Equirectangular Rotated 180" Segment "Equirectangular", 0, 0, 0, 0, 1, 0, 0 scale 1, 1 Offset 0, 0 Effective -180, 90, 180, -90 Rotate 180 EndSegment EndProjectionI did have ft3 closed when I edited the Projection.txt
Hmm. Mountains become valleys and the oceans become blue mountains. Changing the world seed doesn't make it look different.
Fixed it by changing the offset from 0,0 to -0,-0.
Sorry, that didn't fix it.
Anyway, I guess jslaytons suggestion is probably easier anyway.
