Text on map questions (please help)
                    I am an absolute beginner, but from what I have read here it looks like some of you are professoinal auto-cad programmers. Please forgive the inanity of my questions but I am a straight up beginner.
1. How can I get my text labels in CC3 maps to remain "above" trees and other entities? I am just too retarded to figure it out, even with the help guide.
THanks for any help you can provide my fellow hobbyists. Matt, Boston MA USA.
Before placing text, just look at your status bar at the top, to make sure you are on the text sheet. If you aren't, click the indicator, and select the text sheet before placing your text. For already placed text, use the '"Change Properties" command on it to change sheets
Note that in the sheet dialogue, the further down the list an item is, the higher up it gets drawn. So the items on the last sheet in the list gets drawn on top of everything else.
Except - now when I go to add text, it goes through the normal "text properties" window, but when I hit ok, all I have is a crosshair that does nothing to the map. Am I on the wrong layer?
By the way, thanks for the help...
A good way to get the appropriate value, is to use the "Info -> Distance" menu item to measure the desired text height on the map itself, then insert that value into the properties box.
Also, you do type in the text to be added to the map, right? If you just bring up the properties window, you are not actually adding text, just setting default properties. Make sure you bring up the actual "Edit Text" window, where you type in the desired text, to actually get any text to place on the map.
Yeah, I was drawing text about the size of a blade of grass...
More questions to come, trust me.
Keep helping me like this and I will be sending money to your paypal account. Your advice is valuable to me...
Thanks
Matt (GreenBeginner, feeling greener every day)
In the mean time, enjoy mapping...
To correct this on your map:
1. Select Sheets and make sure that you have a TEXT sheet above all the symbols, possibly below the GRID.
2. Select Drawing Properties on the File menu.
3. In the box labelled Text Sheet type TEXT*.
This means when you add text to the map, it will be added to the TEXT sheet, regardless of the current sheet. (It will also add to any sheet in which starts with "TEXT", so that you can have TEXT SMALL and TEXT LARGE for example)
I am trying to map Westeros (the North mainly). If any masters out there have already worked on this, I would buy their work in a second.
Any advice is appreciated.
