Cosmographer and CC3 - Editing Sector Names
                    Hi all - having some trouble with the Traveller sector and subsector mapping tools in a CC3 installation.  For the life of me, I cannot figure out how to select and edit the Sector Name and Subsector name that appear in the upper right of the SectorE01.fcw tutorial, for example.  The tutorial text says I should be able to click the Edit button (presumably this is Edit - Edit Text - Edit text since I show no such button), select the 'Sector' text and edit it, but when I do that I cannot select anything in the template except for text I added myself - the Sector, Subsector and other template text cannot be modified.
I am sure I am missing something stupidly obvious here - can some one give me a clue?
What confuses me is why ERASE should appear for you. THe command has been replaced with ERA in CC3. What are you using to start the command? The eraser icon on the left toolbar?
When I use the Numeric Edit (after Unfreezing the Background layer), I can select titles on the Subsector mapp, but not on the world map - in that case its not as big a deal as there is plenty of room to add a planet name and information.
I also run into the problem mentioned earlier with the World map template, where the hexes 'spill over' off of the map and into the open spaces between.
I guess what I am starting to wonder is if it was really correct to say Cosmographer is CC3-ready. Is there a plan for some additional Cosmographer patches?
In any case, the workaround to using the command from the menu/toolbar is just to type ERA on the command prompt in CC3 to erase it, or edit the cosmographer.mnu file found in the CC3 directory, and replace ERASE with ERA-
There does seem to be a problem with the world map that causes the hexes to show outside the map area. I've explained a workaround in this topic.
