Where Can I find the syntax for CC2 or CC3 commands?
                    There is a list of commands in help.   However this is just a brief description of what they do and does not give the syntax for how they are used.  Is there a published manual of command syntax available?
Thanks
John Barnes
                            Thanks
John Barnes
You usually don't need to know the syntax of most commands though, the command line will always tell you what you need to input next when you enter a command.
What is "The Tome?"
Thanks,
John Barnes
As for the Tome, I am referring to the Tome of Ultimate Mapping
John
I also found the command syntax I was looking for. I is in an excel spreadsheet that installed in C:\CC2\Documents\Tome in a file called commands.xls.
This is what I was after.
Thanks,
John
I don't think there is really anything in there that isn't also in the book itself, but it is presented a bit differently. It contains all the commands from all the addons combined in one location though, so you don't have to flip back and forth through the book, so it is a highly useful list.
John
