Ortho tool randomly stopped working on only one map project file?
Hi guys,
I'm currently working on tracing a map from a very large JPEG, and to make it easy to follow my progress I generated a grid and am splitting my progress up by each individual square. That was a few days ago - just today I thought the grid was a bit too small and wanted to make it bigger, so I went to the grid generation tool and tried to generate a new one, and did, but then changed my mind and thought I'd leave it as it is.
Since then, the ortho tool (to draw lines perfectly straight) has ceased working - toggling it on and off has no effect. In other map files it still works fine, so I assume the problem is with the specific project file I'm working with, which I have attached. Would anyone know of a way to fix this?
Thanks!
Ortho doesn't like when the snap grid is a hex grid. Right click ortho, and set the grid to any rectangular grid instead of that "user hexgrid", that should fix it.
That worked, thanks! In making the larger grid I generated a hex grid by mistake, that would explain why the setting changed.
