[Atlas Submission] - Doriant - Gold Coast - Eknapata Desert - Kukaar
Hi Remy @Monsen!
I have discovered an Atlas submission for the city of Kukaar that I either failed to tag you in or quite possibly failed to submit at all. My Apologies! This is ready to be added at your leisure.
This is for Doriant - Gold Coast - Eknapata Desert - Kukaar. You'll find Kukaar in pretty much the center of the Eknapata Desert map. It does not have an unusual toggles.
Thank you!
I really like this!
Thanks @Royal Scribe
In the atlas now.
That was fast! Thank you.
For those who didn’t know, this is designed in the beautiful Ancient Cities style that @C.C. Charron designed for the 2024 annual.
This is why I like these single simple maps without any description text or toggles. They are very quick for me to do when I find the time, while larger map dumps or more complicated setups require more time, so they get stuck in my queue until I have a larger chunk of time available.
(Of course, if a map is supposed to be part of a set (like a multi-floored building/dungeon), it is better to get the whole set at once since it will be less time per map compared to going back and forth for every map as they arrive one by one, but I still need to be able to find a larger chunk of time)
Monsen noted: This is why I like these single simple maps without any description text or toggles. They are very quick for me to do when I find the time, while larger map dumps or more complicated setups require more time, so they get stuck in my queue until I have a larger chunk of time available.
But be fair Remy, you'd get bored if they were all easy all the time 😁!
[He said, as one of the major culprits acknowledged by this quote...😉]
And for @Royal Scribe: I remember seeing this map quite a while back; most impressive still, even though I assumed it had gone into the Atlas back then as well!
Mind you, I'm forever finding maps by others I don't recognise when hunting for places to fit my latest Dungeon24/25/26... maps to. I suspect some probably were never posted about on the Forum, though it's at least as likely I've simply forgotten about them in the intervening years.
Most of my Atlas submissions are organized in folders and subfolders named after the Atlas' geography, so it's easy enough for me to poke through to see what's missing. (I did find one more, but I'm debating whether or not to tweak it before formally submitting it.) There are a handful, though, that were designed before I designed the Gold Coast region, and even though I created spots for them in the Gold Coast, I discovered that some were never submitted. Still going through tracking them down (while working on one of my new cities). And others don't have a proper spot as yet, but maybe if I rename them, they will soon have a home. I love the idea of Game Masters using my maps, and would love to hear about the adventures they were used in.
