Continental Coastline
                    Ok I'm a total noob, I've never even really used any mapping software before so please forgive my.....noobishness.
Anyhow, I want to create a coastline of a larger continental landmass. I'm actually creating from an already existing map, and I want to create a part of it. Anyhow, the problem I get is when I draw the fractal coastline and then right click to finish it, the program takes that line and creates an island out of it. What I want to do is create the line, then fill one side of it as a landmass and the other as ocean. I looked through help and couldn't figure it out. What do I need to do?
Thanks in advance.
Thanks in advance.
The point to remember about CC3 is that you don't draw a dividing line, then fill the various part, but rather draw a complete object like a landmass on top of the ocean below. This is why you need to draw the complete landmass as explained above, since CC3 will automatically draw a line between your ending point and starting point, and fill the resulting object. Thus, you need to draw in such a way that your ending and starting point is very close together to get full control over the shape.
To change fill style of an existing landmass, use the "edit Properties button" (OR the "change properties" one), and select your new fill style.
Note that for an object to appear filled, the "width" must also be set to 0. (If it is set to a non-zero value, you get a filled border around the entity, of the defined width, instead of filling the entity itself)
I suck at this.....
Also, make sure that the entity you are trying to fill is actually closed, as a non-closed entity cannot be filled. If you used the landmass drawing tool to make it, it automatically draws a closed path, but if you used any of the path drawing tools, it might not be closed. Note that in a CAD-based program like this, an entity isn't automatically closed even if you manually place the end at the same place as the beginning. You must use a polygon drawing tool.
CC3 has a certain learning curve, because it is quite different from normal drawing/image processing software, like Photoshop or similar. The best way to get properly used to the program, is to start out with the tutorial in the quick guide. Then, get the Complete Cartography Suite from your registration page (You'll need to register CC3 if you haven't already). This manual is for CC2, but most of the manual is still very valid.
It is for CC2, but many of the same principles are used for CC3. It has lots of tutorials in it and will be helpful in getting used to the interface.
The registration page at profantasy.com, log in. and look down the right side of the page.
