Galery of NPC
Mathieu Gans
                🖼️ 29 images Traveler
            Here's a small gallery of NPCs I created for a game.
I'd totally forgotten about them. As I've just found them again, I'm sharing them with you.
These are amazing. Were the characters done in Character Artist? I haven't played around with it enough to see how versatile it can be.
A wonderful combination of symbols and creativity.
I think most, if not all, the character items are indeed from Character Artist, RS - I recognise many of them, certainly!
Excellent! I didn't realize how versatile it is. I am going to have to spend a bit more time with this add-on.
Hello everyone,
Thank you very much for your feedback.
I only used assets present in Character Artist 3, Campagn Cartographer 3+, Perspectives 3, City Designer 3, Dungeon Designer 3, Token Monster 1 and 2, and various Cartographer's Annual.
At the moment, I've kind of given up on Character Artist 3, as I find the characters too static. I'd really like an Add-on that would allow me to give different poses to NPCs, have more assets for equipment, and effects to put on characters. But I think that would be extremely complicated and expensive.
In any case, see you soon on new projects!
Best regards
I have used the move command to change positions of body parts and weapons and such.
Sometimes you have to play around with moving sheets around. Weapons and such may need to go above one extremity and below another. It's a fun toy.
Mathieu Gans remarked@Mathieu Gans: At the moment, I've kind of given up on Character Artist 3, as I find the characters too static. I'd really like an Add-on that would allow me to give different poses to NPCs, have more assets for equipment, and effects to put on characters.
There are more options in the original, vector-style, Character Artist, and it's much easier to draw additional elements when you need them in that. It is a simpler and much less "artistic" drawing style, however. It does though give you more control over what characters drawn using it look like.
Is the vector version still included?
Yes. Just pick the CA Pro template instead of the CA3 template. Or for a full selection of the old templates, use the "Pick a pre-defined template" option in the first step of the new map wizard, then in the template select box, hit Select Path and navigate into the CAPro folder and into the desired subfolder, pick any of the templates and hit ok to preview them all in the template picker dialog.
