Adding a scale and compass
I created a map but did not include a scale or compass when I chose my initial map layout. How can I add a scale of miles and a compass after the fact? I don't see it in the tool menus.
Most templates have references for these available as part of the template.
Hit the Symbols in Map
 button, and you'll most probably have them available near the top of the symbol catalog window.
Also if you add the scale bar in. Change the size of your map so it corresponds with the scale bar. That way you can use the distance function if it's for gaming. Having everything to the proper scale is pretty handy. Especially if you intend to use child maps(zoomed in maps) later.
Ah, I found it. Thanks for the help!
