Cosmo 3 Draw Hull tool
I am probably missing something simple, but the ToUM doesn't cover Cosmo 3.
When using the Draw Hull tool, how do you make curved hulls?
The way i have done it so far is draw it out first by putting in a lot of points along the lines to make the rough outline. I then add points along the lines to smooth out the rough spots. It's certainly NOT perfect, and if anyone has another (i.e., easier) way to do it, i'd be all over it :-)
Let me know if you find a better way.
It seems to me there has to be a better way than roughing and adding many points. I have yet to see a ships hull that is square and a hull tool that will give you both sides of the hull but only in straight lines is pretty much useless.
There has to be a super secret command that allows for curves.
I came up with some hull changes for my starship site. I wanted to make curved corners for the main hull. Instead of a square hull, or a circular hull.
So I drew a square grid, with the corners being made using Arc.
the bottom of the 2 maps.
Sorry, I don't remember which template I used. Likely city or overland since I didn't feel like spending lots of time removing everything I didn't need from the Cosmo deck plans.
The hull draw tool allows you to draw a hull shape in one series of actions. If of course the hull is square.
Self torture I guess
Just an FYI that i tried your method out last night messing with various ship hull designs and i LOVE it! Thank you very much for your help with this.
Has anyone else noticed issues with it not quite working right when you select certain ship templates, though?
