1. Create AI-generated images of maps that come with interesting decorations.
2. Use this image as a Trace and add Transparency to this Sheet.
3. Place the Sheet Trace under the Land, and draw the outline of the Land on top of the image.
4. Arrange the map as I see fit with the chosen motif and keep this sheet trace transparent when I export the JPG.
I'm attaching the image and the file; I think you'll just have to "fit" the image back into the trace to get a better idea of what I'm talking about.
The only difference is that I made the islands on the moon and inside it. I used a nebula image in red tones with magic symbols (a prompt more or less like this) and I also left it on the sheet trace (below the land) and gave it some transparency so that the image wouldn't be so apparent in the background.
This is so beautiful! The background map on the corners -- is that from CC3 or did you import it from another source. It's fantastic.
I'm trying out a new possibility:
The colors are later retouched in Lightroom.
I used more or less the same sequence on the Moon Islands.
https://forum.profantasy.com/discussion/14696/moon-islands#latest
