This Should Not Be Happening! AKA glow problems
In a previous incarnation of this map there was a nice 'fuzzy' edge to the water, but despite copy and pasting the effects into this version the water has got an edge but it is on even when the effects are OFF! I didn't change any settings after pasting from the original file, I promise. The first 2 are from the original files and the last is from the most recent version.
The sheet effects are on in all three screen shots. When you switched them off did you hit the Apply or OK button?
yes but I in my experience when i turn something, like a glow on a sheet off, when i hit OK it changes when the panel closes, Sue. Here's the two files. The file that has FCW before the extension is the old file [that works as i expect it to do].
Is this right?
If it is, then what I did to get it there was switch off the Outer Glow on the 'dragon' sheet, and move the lake to the WATER/RIVERS sheet and layer. It (the lake) was on the 'dragon' sheet.
Here is my version of the file.
ahhh, I see. Thanks Sue.
You're welcome :)
