Links stopped working
I have a floorplan map and the links have stopped working when I changed the font. I deleted the old hotlinks and tried to add new ones but this is what I am getting. It is showing the text of the link and the link still isn't working.
    I haven't noticed this before, but it does seem that something weird happens to the hyperlink if you change text properties on it using the change properties dialog. I've reported this to the developer.
    For now, I recommend being careful with change properties and make sure only the text is selected and not the hyperlink (You can always make hyperlinks temporarily visible from the View Menu)
    You should be able to make new ones though, at least I was able to after reproducing your issue. Just make sure to draw the hotspot properly around the entire text to link, the hotspot is a separate rectangle, not actually part of the text.
    Glitch
  • That ended up being the problem. Somehow all of my hyperlinks were visible. Thanks.
