online campaign map for wargame
I would like to start a miniatures campaign for exillis wargamers.
Basically they would be a map of old Europe each player could login and move there five graphic icons only one region on the map, administrator can freeze movement , to end turn . once two icons were in the same region, players would battle after the battle results in a tabletop miniatures game, one of the icons the loser would be removed from the map.
Is there way to use profanity in an online interactive way?
    There are several programs to run games over the internet. i haven't used any of them though.
    And i presume you mean 'Profantasy' ?
    Note that the ProFantasy tools allows you to create the maps which you can use for such a purpose, but they do not contain any kind of online interactivity built into them. You will need another program, which there are plenty on the net as JimP pointed out, to run the game, but you can use Campaign Cartographer to draw the actual map to use with these programs.
  • You might want to check out RPTools (http://www.rptools.net/). It was mainly designed with RPGs in mind, but it can handle custom rulesets, imported maps, dice rolls and either square or hex grids. You can even implement things like fog of war if you need it. Creating custom rulesets is a bit difficult, but simple stats and dice rolls are very easy.
