New Watabou and Change Like DT
 Calibre
                🖼️ 39 images Mapmaker
Calibre
            Greets
While working up a city for my campaign, I decided on another WATABOU style (using 2024 revised version - metric). When I get to the point to 'change like' for the towers, I get this:
I've checked and double checked effects and made sure the version is correct. I installed watabou 2024 and right after, update 28.
Soooo, any ideas what the deal is?
thanks
Cal
Interesting enough, the Build top, circular works perfectly.
hmm
Cal
Can you post the fcw with the offending bit? I will take a look.
Yeah, sure...woulda done it already but thought I had altered something...
Cal
Your map drawing units are in feet, not metres. So the walls are only 3 feet thick, not 3 metres thick. Perhaps you chose the wrong unit to begin with??? That is why you are getting the result you are seeing there, I think.
I thought for sure I'd chosen metric
How did that happen? hmmmm. Even converting to metric doesn't fix. I'll start it over then.
thanks, Quenten
Cal
I have rescaled the drawing, so it is in metres. Also, the effects were set as imperial, not metric - I have also fixed that. Not sure why it didn't work properly if you did choose metric rather than imperial at the beginning. The bitmap resolutions may need to be altered though.
Weirdness...was late at night and getting considerable 'bugging' by friends and family. Probably that.
Thanks for the conversions!
Cal
My pleasure.
Yeah, the fills had to be scaled properly. All done.
thanks again
Cal
Looking forward to seeing the city
