Easiest way to size and link a smaller scale map
Frosty
š¼ļø 22 images Surveyor
What is the easiest way to start a smaller scale map from a larger scale map. Example if I use the Map of the area North of the Evermoors from the FR Atlas and I want to create for smaller scale maps of the area. My thoughts are measure the size of that map based of the Scale in Miles legend at the bottom right. Then create a new map with dimensions 25% of that one. Then take a BGP of that portion of the map and import it on that layer in the background stretched across to use it as an outline of the area.
Is that the easiest way or is there something simpler?
I have some tips here:
Oh interesting thanks Monsen
