How do I fill an area?
Lord Scarab
Newcomer
Hello, I traced a map of Austria Hungary with the smooth path tool. Is there a way to instantly fill the interior with a landmass?
Lord Scarab
Newcomer
You can convert the line to a polygon using 'Path to Poly' in the right click menu of the Fractalise tool. It looks like you might have a line width greater than zero, which will form an open polygon. Use Change properties to set the line to zero width and pick your fill, sheet, and layer.
