PDf woes -anyone seen this and know what to do about it
HI all
Has anyone seen this before? Just to say I am printing to PDF using Bullzip pdf as per Ralf's suggestion and so far this hasn't been a problem, so don't know why it is here? Just so you know the stone texture should continue into the room, as far as I know its a solid poly bmp fill.
I've continued to be able to print off other sections of the map but whatever I do I cannot so far make this part render out?
Ab
If that's the case, try to separate the polygon into smaller sections so that an edge crosses the area.
If that's not it, send the map over. I'll take a look.
Here is the FCW attached.
Ab
will get back to you
Ab
Ab
Thanks again Ralf.
Ab
