Troy Map for Game
Calibre
🖼️ 38 images Mapmaker
Hey all!
Happy Autumn/Fall/Spring etc...
Here's an update map of what I've been working on:
I'd appreciate any critique.
thanks
Cal
Looks great !
Nice. At first I thought it was fir the ancient battle of Troy, but then I saw the Montana at the end. What sort of game is it?
Thanks, everybody.
It's post-apocalyptic Earth set in the US. GM is using 5E rules for it. Basically, the Solar System has entered a region of space where the laws of physics have changed so that magick works, supernatural creatures exist and so on. Fun, so far heh heh.
thanks
Cal
Hey all,
Just to add to this:
1: Forgot to turn off 'restrict to map border' so the roads get wonky at the edge of the map. So, working with /stretch/ operation to fix those errors
2: I followed the map exactly. This means, you'll find dirt roads right up against the paved ones (who knows why; it's Montana), so I'll need a way to fix those areas. I'll probably just take artistic license and alter these roads as seems logical.
3: Any remaining 'straight lines' on the forest will be dealt with.
4: I dislike the water fill on this style; therefore, going to advert to one of the ones Ms. Sue has created.
5: Unsure whether I should show the building blocks ala watabou style or not (the map is in this style).
I'd appreciate any advice
thanks
Cal
Why is the cataract coloured purple - some deadly algae bloom? (like the pink lakes in Australia)
Heh! Well, it's a flow of essence, basically magick. A ley line just depicted visually as normally these cannot be seen. GM wanted it that color. I guess to stand out? Anyway, normal humans in the game cannot see this at all.
Cal
