Roads and cities
Hi
I need an answer to what is probably be a very simply question.
I have laid down the cities and towns on my current map, but when I lay down the connecting roads, they are laid down over the cities and towns.
How do I get them to lay below?
The road tools should automatically place them in the proper sheet, the ROADS sheet (or equivalent), and it should be below your SYMBOLS sheet.
So, from the above, there's a couple of things to check:
Then again, the map styles usually have the tools setup so that all this happens with minimal intervention.
Which style are you using?
Thanks Roflo1, the road sheet was higher then the symbols sheet for some reason.
All sorted now.
Many thanks.
