Rotate by a specific number of degrees
I'm trying to rotate an entity by exactly 22.5 degrees. Is there any way to do that by entering the desired rotation, or do I just have to "free rotate" until I hit my desired target?
The rotation commands allow you to type in the exact amount on the command line. I recommend the non-visual rotate for these operations, which you find by right-clicking Rotate
Control + Shift allow you to smooth rotate and angle as you want in visual mode.
I didn't know that, thanks Ricko !
Thanks @Monsen - that did the trick.
I tend to forget that right clicking on function buttons offers alternative options.
