toggle menu
Sign In
Register
Sign In
Register
Sign In
Register
Home
Mapping with ProFantasy's Software
Fractal Terrains missing feature?
herrozerro
July 2010
in
I cannot find a feature that I once used after I updated. It was one where you could use a custom shader from a file.
Is this gone for good?
Share on Facebook
Share on Twitter
Monsen
Administrator
🖼️ 82 images
July 2010
edited July 2010
I assume you are referring to Fractal Terrains here, not Fractal Mapper (Which isn't made by ProFantasy)
Anyhow, to use a shader from a file, go to
Show Other Shader
Show Image Climate
Here you can load your own shader file.
Share on Facebook
Share on Twitter
herrozerro
July 2010
Yes, Fractal Terrains.
The only options I get there is Bump Map and Normal Map.
Like I said, I used it before and then I updated to 2.2
Share on Facebook
Share on Twitter
Monsen
Administrator
🖼️ 82 images
July 2010
hmm. I am running version 2.3 here, so seems like you might be missing an update. The 2.3 update should be available from your
Registration Page
Share on Facebook
Share on Twitter
herrozerro
July 2010
that was it! thanks!!
Share on Facebook
Share on Twitter
Sign In
or
Register
to comment.
Map-->Show Other Shader-->Show Image ClimateHere you can load your own shader file.
