Using Ferraris fill styles on other maps
Aloha.
I am currently trying to get Altdorf (yeah that one) as a Panoramic map (Annual 103) but I want to use the Ferraris "arable green and red (but mostly green) " fill styles for fields. However the transparent (white) parts of the png texture refuse to let me see the underlying colour. It looks like this:
where I was expecting something like this:
The first one is in a map, created with the CA103 Wizard (Panoramic City) the second with CA158 (Ferraris).
Any ideas? I have tried to make 255 255 255 (pure white) transparent... however that looks a little snowy:
Thanks!
Cheers
Olaf
Take a look at the sheet effects in the Ferraris style. The sheet with the fields on it will probably have a blend mode set to multiply. You will need to copy that sheet effect across to the map you are making.
thanks, that did it.
