Community Atlas - Forlorn Archipelago - Poncegraf Village - Church
Here is the church and parsonage for the village - and I will be doing details of both buildings.
  • I know there are a few things that need tweaking, like straightening some of the fences, fixing the fields etc. I am at a bit of a loss as to how to do the bit about the cliffs though - so the hedges don't seem to overshadow them.
  • Great style mix - love the vivid, slightly psychedelic colours and the generall mood/impression of the map.
    The only things bugging me are the entrance gate to the left-side fields (Shouldn't the posts touch the hedge?) and the right side of the main path, where there seems to be a piece of "churchyard-texture" on the right side of the path.
    Maybe some slight edge fade on the paths would also make them blend in a bit more.
    [Deleted User]
  • I am at a bit of a loss as to how to do the bit about the cliffs though - so the hedges don't seem to overshadow them.
    You could try adding a new polygon of the surface fill texture above the hedges sheet, but below the cliff symbols sheet. You'd have to draw it either exactly along the outside of the hedge symbols to retain the impression and hide the hedge shadows, or draw it quite close to them, so only part of the shadow is still visible, however. The latter might look a bit oddly sharp-edged though.
    So alternatively, you might try moving the problematic hedge symbols to a new sheet with a smaller shadow effect, suggesting they're closer to the rising lower hill surface behind the cliff-line.
    You could also redraw the cliff line as shorter and lower, so the hedge shadows aren't so obviously problematic.
    [Deleted User]roflo1
  • Here is, hopefully, my final rendition. I also have started on the interiors of the Parsonage and Church - I need practice on churches.
  • Here is the Parsonage. I still have to work out the scale - I may have to rescale everything from the fief downwards - I can hear Remy groan already.
  • Interesting to see the "bo(u)lder" approach you took to the hedge shadows problem 😁
    [Deleted User]
    Remy - please can we have a 'groan' button?
    LOL!
    JimP[Deleted User]
  • Why thank you Sue! Just getting into practice for the livestream...
    LoopysueJimP
  • OK, here is the map that I am now satisfied with, with the scale increased by 50%, and converted to metres. The Church is now 73 ' which seems better to me.
    Of course, the fief, and manor house, which are already in the atlas will need reconversion, but that shouldn't be a problem as only the new scaling has to be added, and as I will use the Atlas maps to do this, all Remy needs to do (I think) is just upload the corrected FCW into the Atlas.
    And the Parsonage, rescaled and finished
  • Converted to feet, I meant - did the same with the fief and Manor house, so all the scales are now reconciled.
  • The Church Floorplans are finished
  • Every grave has a stone cover? Isn't that a bit expensive for commoners? A tombstone at the head of a grave mound is more what I'd expect for most of them. The mausoleum would most likely be used by the noble family and have more than one member interred there.
  • For the Church, the pillar shadows could use some adjustment, as right now, they're passing over and through the walls, which is confusing.
    On the upper floor (which might benefit from labelling as such), the stained-glass window patterns thrown on the floor need adjusting, so they cover only where the wooden flooring is - where they shine into the air beyond, there should be nothing.
    Additionally, not all the windows should be showing these at all on either floor, only where the light will be shining directly through them, and that should match with where the floor shadows lie as well.
    It might be helpful to add dashed or transparent lines on the lower floor image to indicate where the upper balconies are on the lower map view.
    [Deleted User]JimP
  • 26 days later
  • Notes for this map, which will be delivered to the Atlas today. Thanks everyone for your helpful comments.
    Poncegraf Church
    The Church of St Lionel (previously St Stefan, but forcibly changed by the current lord to reflect his own name) is a grey brick building, with an upper floor for the choir and organist. The small cemetery is mainly for the lord and his family and retinue – serfs are mainly put in a common pit-grave in the woods.
    The priest is a mouse of a man – Father Harold Limpet – completely incapable of standing up to Sir Lionel’s autocratic and tyrannical demands. He is aware of the sexual depravity of Sir Lionel, and is confided in by Sir Lionel’s wife, but is completely lacking in any backbone when it comes to even a mild admonishment when yet another wench is pregnant.
    He does run a small school in the church itself, three days a week, teaching reading, writing and theology for a small payment in kind from the serfs, and silver from the Lord’s retinue. Sir Lionel’s children are taught by a private tutor, of course (and strangely always female, and many, even more strangely, having to leave because of pregnancy). He also is known to give some of his own goods to help those in great need. He is loved by the downtrodden serfs, and despised by Sir Lionel, and used by Lady Poncegraf.
    He lives in fear of being dismissed by sir Lionel (no hope of that, though – Sir Lionel loves having such a cowed man as the village priest that allows him to get away with everything and anything). He HAD been dismissed from his last parish, because he was such a mouse of a man, and has no desire to experience the months of homelessness he suffered after that dismissal.
    And to top it off, his wife is not only plain, but is a very controlling woman with a loud shrieking voice. Though. To be fair, she does also look out for the villagers, and has occasionally ticked Sir Lionel off about his ‘affairs’, much to the chagrin, and even fear of her husband.
