Duskwood Manor - A Village Scale Mood Piece
 EukalyptusNow
                🖼️ 62 images Surveyor
EukalyptusNow
            I'm currently experimenting with cliffs and height differences and also felt like creating a fantasy-horror encounter map.
I've used the annual Darklands Cities style as base, with Annual City Cliffs and some symbols and a texture from Dungeons of Schley.
Think that the upper cliff edge crack "halos" come out too bright. I might try to create more stone ground around them. Not too happy with the results of my attempts in the Southeast corner of the lower plateau yet.
What do you think?
![[Deleted User]](https://secure.gravatar.com/avatar/c75d9a245b74d9c59be0999ea81ca541/?default=https%3A%2F%2Fvanillicon.com%2F92add7f8c954488718110edc4896ad39_200.png&rating=g&size=200)
I think it looks pretty good :)
You can change the colour of the cliffs using either an Adjust Hue/Saturation or Colorize sheet effect on that sheet. While these effects don't normally work with symbols they will with the cliffs because the cliffs have map files.
Thanks a lot, Sue. Did not think I could add these effects to the cliffs.
Added a slightly darker hue and edge fade, which also reduced the "floatiness" of the cliffs.
Also added a floor for the buildings with holes in their roofs and a additional bits of "rocky fade zone". Like it better now.
