smooth path mistery
Humble ask for help:
I used smooth path - as always - to have some texts on maps, like everyone do.
I draw in blue where supose to be smooth path before insert text, all the text was in correct order except the down one.
this one always appear upside down, y tryed to make and remake the line and text many times and always appear in wrong way. What supose to happen to generate this problem in only this "sector".
thank you
Have you tried unchecking all the checkboxes in the dialog? The automatic alignment doesn't always find the correct orientation.
works Thank you
Yes, the Text Along A Curve issue still remains problematical since it was changed a while ago. This topic covers up to where we are currently still, as far as I'm aware (which means Monsen's advice is what you should always do as standard now - uncheck the boxes - to get the command to work).
Except don't uncheck the box to remove guideline after finished.
