Darklands Border Tool
Hey all,
Having issues with the Darklands style border drawing tool. I checked the tutorial/guide but no data.
Anyone used this who can advise how to use this properly? So far, the borders don't show separately but combine instead.
As you can see with the orange line, I drew another border poly to connect off the larger area to the coast. Instead of a border line showing between the poly's, they merged to form one large area. I'm clueless how to use this tool properly, apparently.
thanks
Cal
It was desinged to show one country per map, with a sort of vingette of dark purple around the outside of the red line.
However, if you adjust the sheet effects by deactivating everything that is there and adding the usual Edge Fade, you should be able to create them just like you can on an MS overland map. You may have to modify or create a new border drawing tool, so that it draws with the current colour instead of always drawing in bright green.
Thanks, Sue :)
I will
