CSUAC available for CC3
                    Thanks to Gerri Broman, the CSUAC is now available to support CC3!  This has over 5000 images in PNG format and fills, already sorted in the CC3 file structure.  And more is on the way!  The current task is organizing 3000 structural images (buildings, roads, bridges, etc) with an intent of having it ready at the end of the month (early July for CC3).
This is great news.
I really appreciate the hard work of both you and Gerri, as well as all the artists that have contributed to make this possible. A big thanks to all of you.
Throwing myself at the download now, looking forward to the next instalment.
You can find the downloads at GM's Apprentice (Registration required to find and download the files). Just look for the CUSAC link at the top.
Make sure that your downloads completed successfully. Check the file size of your downloaded zips against the list on the site to make sure they are the same.
Is there something I have to do other than unzip it and put it in the directory that is listed in the pdf files? I've done this and I can't access the CSUAC in my CC3.
If you have done this, and all the symbols shows up as the "not found" image, it means that your catalog structure is not correct. It need to be exactly as listed in the pdf, no additional or missing levels.
c:\program files\ProFantasy\CC3\Symbols\CSUAC\BL1_CC3_Creatures\Art Files\[Category folder (Abberation, Insects, Rats, etc...)]/*.png
The other packs should have an identical structure, except for the name of the pack, obviously.
If the symbol catalog file is broken you can create a new one yourself, using the symbol manager, or you can just open up the artwork folder directly instead of using a symbol catalog at all. For the last option, click the open symbol catalog button as usual, but instead of opening a catalog file (*.fct file), continue into the artwork folder, and select one of the .png files there instead. All the png files in that folder will then appear in the symbol chooser, regardless of which spesific png file you selected.
Oops! Sorry for the inconvenience.
____________________________
Gerri
Also, if anyone identifies a common error in installing the files, please let me know and I'll get a FAQ started.
I'm sorry, but I'm afraid that I'm not going to be of much help in solving any of these issues with you, as my personal experience with CC3 is rather lacking.
btw: thanks for all the work! It's great to have all the symbols already sorted in catalogs!
Again, I'm sorry for the hassle but like Cecil said, with this many files it's not surprising that a problem came up.
Let me know if there are any other problems.
Send the email to solomoncecil (at) yahoo (dot) com, containing your name, your desired username at the site, and your email address.
You need the exact url though.
