Looking for a rising sea level map
There is an amazing, interactive map at geology.com/sea-level-rise, that lets you set the amount of sea level rise (from 0-60 meters), and zoom in anywhere around the world to see the effect of that rise. This is exactly what I'm looking for, except that I would like to see much more than a 60 meter rise.
I'm curious how far the sea level would have to rise for the continents to become unrecognizable. I think such a map would be a wonderful addition to a post-apocalyptic campaign.
Anyone know of such a map?
Now I just need to locate a high rez data map for earth to put into FT3.
Sorry for the thread necro, but HOW? I've been digging around off and on for months and cannot find how to adjust sea level in fractal terrains on a point value generated map. I'm trying to use the map of Mars and would like to play with the hydrographic percentage or shift sea level away from the nominal 0 level in the data. I can't figure it out. Any help would be appreciated.
Thanks,
Jason
Tools -> Global Raise -> Water Level will rise the water level by the specified amount. Works fine on the mola2x2a Mars data if that is what you are using.
It is what I'm using. Thanks so much.
If you're using a binary file as the data source, you'll need to use Tools>>Actions>>Burn In To Surface in order to get editing tools like raise or lower land to work. It copies the binary data to the Offset channel at the current editing resolution, so you may lose editing resolution when doing this step. On the plus side (maybe), you'll get data interpolation and no longer have a reliance on any external data files because the information will be contained in the FTW file.
