Adding Navigation Lines - Newbie Question
                    Hello, I just finished making my first map with CC3 using the CC2 Pro guide, and I can't figure out how to insert
navigation lines to the map. I've tried going to Draw -> Insert File but can't find it.
Thanks,
Patrick
Thanks,
Patrick
Anyway, If you install CC2 you should get the correct file, but you may need to change it's sheet after importing it. (CC2 should be downloadable from your registration page I believe). Maybe Ralf or Simon can provide you with the correct file directly too, without resorting to installing CC2. I got the file, but I can't post it without PF approval.
Do I copy them to the clip board now? I've tried, but when I try to paste, it says the clipboard is empty.
Thanks again,
Patrick
The default copy command is Copy in Drawing, so you can't copy something from one drawing to another with that command (that's why the clipboard is empty). What you need to do is *right* click on the copy button and you will get a pull down list of copy commands. Select Copy to Clipboard from that list and use that instead to get the nav lines from one map file to another.
Right clicking on many of the CC3 buttons brings up more command options.
Hope that helps,
jaerdaph
- File ->Open the template with nav. lines
- Right Click on the copy button
- Select Copy to Clipboard
- Left Click on the center point of a group of nav. line (I've also tried dragging/creating a box to select)
- File ->Open the other map I'm currently practicing/learning with
- Right Click on Copy Button
- Select Paste
- Nothing on Clipboard Message. :(
Thanks again to all who have helped!
Tools -> Options ->Global Layer Settings and Selected Show All and Thaw, then Apply.
Then reselected, copied to clipboard. Still nothing in the clipboard when pasting. Weird indeed!
Other random things I've tried:
- resaving the template file (.FCT) to a regular map file (.FCW) and then tried again...
- Edit -> Copy -> Paste
If it was another file which contained any other elements besides the navigation lines, you can always edit that file, remove everything but one set of navigation lines, save it, and then use the insert file procedure.
As for the clipboard problems:
1. Are you using the newest version of CC3. Check Help->About. If the CC3 version is less than 3.20, get the latest patch
2. After performing a clipboard copy, can you past the content back into the same drawing you copied it from (Make sure you still use clipboard copy, and not copy in drawing) [The copy command in the Edit menu, or Ctrl+C does perform a clipboard copy as expected]
3. When selecting elements to copy, do the status bar show that anything at all is selected? It should list the number of elements selected.
4. After selecting the elements to copy, did you remember to right click in the drawing and selecting "Do It" [Or hit D on the keyboard], and then select the origin point for the copy. If you didn't, the copy procedure was never properly completed, and would explain why the clibpoard was empty.
