This looks great but it looks like your edge fade inner might be messing with your map a little bit. Notice the bubbles in the terrain and the top and a couple in the fields. If I remember correctly that is due to profantasy having issues with color recognition caused by the fade. If you put a sheet below those sheets that is some weird solid color like purple or something those bubbles should go away. I''m not positive but I think that is what I did to get rid of the problem in my maps. The other solution would be to turn off or reduce your edge fade inner but this is less likely to work. Just my two cents. I still think it looks very good.
Forgot to mention, when you use this solution be sure to apply the same edge fade inner to the weird color layer as you do to the visible layer otherwise you will get leakage from the weird color layer.
