CLARIFICATION: Use of ^DPrompt: to select entities
DaltonSpence
                Mapmaker
                    Some macro commands start with a selection of entities followed by some data on what to do with them. For example:
                            SCLCPY selectEntities;rScaleFactor[Prior];xyOrigin[Prior] If I can put the following data into variables can I use a ^D prompt to select *all* the entities I need?SCLCPY ^DSelect the entities to copy:
vScaleFactor;xyOrigin
SELBY1I could scale-copy one entity at a time in a loop until the select failed (right click). Is there a way to build a multiple selection in advance so I can useSELBYPto run the command? (I want to use this for a macro drawing tool.)DESELECT SELBY1 :StartSel GE p ^DSelect an Entity: ONTEST IFZ ison EndOfSel STORE vEntity pon SELECT vEntity GOTO StartSel :EndOfSel SELBYPNote theONTESTmacro is used to stop the loop when the click is not on an entity's edge.You'll need to reset the p variable for each loop iteration though, GE won't update p unless you click on an actual entity, just leaving it at the previous value, making the ontest retest the previous point (which passed the test then, so should again), creating an infinite loop.
ONTEST’s use in the macro file and there is always anIFERRbetween it and theGE. Here is my corrected code.DESELECT SELBY1 :StartSel GE p ^DSelect an Entity: IFERR EndOfSel ONTEST IFZ ison EndOfSel STORE vEntity pon SELECT vEntity GOTO StartSel :EndOfSel SELBYPWould this work? Do I even need theONTEST?DESELECT SELBY1 :StartSel GE p ^DSelect an Entity: IFERR EndOfSel STORE vEntity p SELECT vEntity GOTO StartSel :EndOfSel SELBYPThe description of theSTOREcommand is “Stores a reference to an entity in a variable, so it can later be selected by Select Entity.” Is this a different data type than that stored by theGEcommand?
