Background only in ... apricot?
Another weird thing I stumbled into while re-working an old map. When I try to change the background colour it does not matter which colour I choose as solid fill - it always turns to what I would describe as apricot. See pic attached.
It was a bitmap fill before and chosing another bitmap works fine. Changing other entities works also, as you can see from the cave floor part I changed to solid fill for testing purposes.
I could just use a black bitmap, but I'm curious what is happening here.
Are you using the Change Properties button to change the colour?
