CA21: Metric Battle Map
Currently I am trying to prepare a few battle maps for our game tomorrow. Problem is, we use metric instead of imperial units and I am having trouble setting the map correctly up. Following a tip Monsen gave a few weeks ago regarding the transformation of an imperial into a metric map I was able to come up with a map with the right dimensions and a 1m*1m grid. But the bitmap fill styles for floors and walls do not look right.
Any hints?
Any hints?
![Kreuzzug - Battlemat 02](http://farm4.static.flickr.com/3587/3536680132_7acb54b09a_o.png)
Click on the Fill Style Selector (upper right), select the style you want to edit. You will see a scale property somewhere at the bottom of the window. From the Help I got that those scales are in the drawing units.
Hope it helps.
Is there an easy way to edit all fill styles at once or do I have to change them individually?
Just in case anyone wonders. Here is the advice from Monsen I was referring to:
Then`ll have to do it the hard way. Wish there would be more support for the metric templates (especially for the annuals).
My recommendation: Don't change the scale of all your fill styles, just set the grid spacing to 3.28083 ft. for 1 x 1 meter squares and use the regular i.e. anglo-saxon templates.
