1) A market near the central area 2) Decorations in the city like statues, smoke and fountains 3) The houses outside the city 4) Brake the monotony of the area between the city and the forest.
Main city done/almost done. I will just try to work on the floor of the main city so it stand from the others enviroments. Now lets work on the outside part!
Advancing! Someone knows any good tecnique to enhance my cliffs? I tryed to draw some lines but it did not turned good... And my fields? What you guys think about then? I will increase the streght of the texture but, ohter than that, I dont how if I can improve it.
Did you try adding a Blend Mode to the sheet with the fields on it?
If you do, you will need to edit it and try some of the alternative modes to just the "Normal" one that's set as default. "Overlay" can produce some interesting effects, as well as some of the others. The Blend Mode sheet effect works a bit like some of the PS or GIMP filters.
I will toy a bit more with effects and the fields. They are still a bit odd... I tryed 2 Blend Modes and both got a lot strange. I have to try the others. About Overlay, I will see that. Thank you
I am almost done here! I just need to decide if (how?) I put the text of the labels in he map. And maybe a compass. I tryed to writte the labels in english here but I am not sure if I did not made mistakes.
Posted By: Quenten17 should be Market - but my guess is that it is a typo, not a real spelling mistake.
Yes. It should read Market. I will correct that.
Posted By: QuentenAny chance of adapting this (just change the name of the city, and perhaps not even that) so it can also go into the Community Atlas?
Depends on what you have used to make the map - any symbols or fills not in CC3+ (including all add-ons and annuals) or CSUAC2 and Dundjinni Archives. If not, then all you need to do is place it. I will help with this if you like.
Posted By: QuentenDepends on what you have used to make the map - any symbols or fills not in CC3+ (including all add-ons and annuals) or CSUAC2 and Dundjinni Archives. If not, then all you need to do is place it. I will help with this if you like.
Probably I did use things from outside. For sure I used one or two of my own...
Maybe some fields around it? And a few trees dotted along the boundaries?
Looking really good
I think the ground in the city itself is ok. I'm looking forward to the fields
It's not an absolute necessity. The map looks good as it is
Now I need to put houses, some trees, labels and small details
Edit: Click for high-resolution version
Labels:
1 - Boyar's Arm River
2 - Forest of Indifference
3 - Bird Grove
4 - Bloody Tree
5 - Temple of the Hands
6 - Hill of the Flies
7 - Luckless Pond
8 - Red Mill
9 - Ivan's Refuge
10 - Yamada House
11 - Boyar's Comfort
12 - Boyar's Pass
13 - Military District
14 - Moskayev Guild
15 - Sisterhood of Lilia
16 - Winter's Palace
17 - Market Square
18 - Guard Cell
19 - Lilia's Protectors
20 - Balaroyka Guild
