The Barrow Hills, kinda like the barrow downs in lord of the rings. but with an evil wizard named Valsorn living in mountains to the south and plotting to raise an army of the undead.
I like the effect on the mountains but the forests look quite overcrowded. Personnaly, I would only scatter single trees over the area but it's your choice.
The inner walls are a bit difficult to see. Adding a wall shadow effect to the sheet would greatly enhance the look I think. What about a bar? Also if you put the stairs on different sheets you could show clearly which one goes down and which one goes up, the latter with again a shadow.
Wow. You use a lot of symbols.
Sorry that I don't have more symbols on the map I only have cc3 not dd3
the stairs in the bottom right corner goes to the upper level
the stairs in the top right corner leads up to the inn keeps room
the trap door in the top left corner goes down to the cellar
What about a bar?
