More work on symbols - Fill with Symbols and Fill Area
roy.denton
Traveler
I am continuing my work on an updated Harnic style and working on trees and bushes now.
These are the symbols I am using for this and the fills I have completed for now. Any suggestions would be appreciated.
They are: Tree and bush symbols; light scrub; dense scrub; coniferous forest; deciduous forest; mixed forest.
While the scrub would usually be made up of many types of bushes the forest may be less varied. I used only four different symbols for this.
Should I consider the following for the forests?
Consider using only one or two types of coniferous trees for that fill, I used three?
Consider doing the same, or maybe up to five different types for the deciduous trees?
For the mixed forest, instead of 7 deciduous and three coniferous trees consider 4 and 1 (or 2) in the same order?
Little Big Horn, Montana
Everglades, Florida
Cape Canaveral National Sea Shore
Hunfeld, Germany
Your three colorful ones look overly dense to me, but if you look at the Hunfeld shot not so much. The scrub in the other three seems to be fairly open, but you have to look around for yourself.
Google Earth zips you to your location unless you set some other default, so you can see how it looks from space and compare it to what you see on the ground.
