Fractal Terrains: Mapping tidally-locked worlds
Hi everyone,
I was wondering if there's a way to do this in Fractal Terrains. I've got a planet which is tidally locked to its primary; it has a "hot pole" always facing the star, a "cold pole" always facing away, and a narrow twilight band habitable zone in between.
Does anyone know if there are any settings in FT that I can use to get somewhere close to this?
Cheers,
Sarah
Cheers,
Sarah
You can use the selection and global temperature raise tools to easily make bands of decreasing temperature from one pole to another, but that's also not quite what you're after for a tidally-locked world unless you define the maps on the pole as temperature poles rather than physical poles. Even if you make such a distinction, FT cannot model this sort of thing correctly and you will need to paint appropriate rainfall and climates manually.
I guess tidally-locked worlds are just a bit too obscure yet! One day! :-)
Cheers,
Sarah
