I just tried it on a few maps and it always happens on the last three town maps that I just submitted and the atlas world map that I've been working on, but no other map that I've tried so far.
Malva map with effects on: -Select Vegetation Sheet and hide everything else -Choose Copy to Sheet>>ALL -Choose any other sheet to copy to -Do it
How big is your map, Shessar?
-Do it
I crash every time unless I turn off effects.
Number of entities does not seem relevant. Crashed on five as well as 1300.
Vector or raster does not seem relevant. Crashes on both.
Version of CC3+ that map was created under does not seem relevant.
Using a selection box rather than the ALL condition DOES NOT cause a crash.
If no one else is having this issue I'll just do a repair install and hope for the best.
Looks like there are some entities that don't like to be copied.
The workaround here is when you do a COPYSHT operation, use the following select criteria:
A(ll) N(not) #(Entity Tag) 0
This will ensure that you select everything that don't have an entity tag id of 0 (special entities)
Your work around works great as does using a bounding box to select everything visible.
